Technicolor router and problems with media sharing across home network
- Technicolor router and problems with media sharing...
11-12-2012 2:50 PM
My problem is that your router will not handle media streaming from my Yamaha amp to any of the servers running on my network. It is not just the Yamaha as I also have problems with my Panasonic Blu Ray player.
After wasting hours with port forwarding, resetting and playing about with different settings I have reverted to my ancient cisco linksys wireless g router and hey presto I have a stable connection from dlna devices and servers. No drop outs, no need to reset devices every few hours - it just works. My conclusion is the technicolor router does not operate well with dlna devices. I suspect a firmware upgrade could take care of the problem. Is there one available and if so does it fix dlna compatibility issues?
Re: Technicolor router and problems with media sharing across home network
11-12-2012 3:06 PM
Yes there is a firmware update available, I'll update your router for you now. Let me now how you get on.
Matt
11-12-2012 4:25 PM
cheers, Chris
11-12-2012 4:42 PM
Yes, when you plug it in it will upgrade itself automatically.
Matt
12-12-2012 3:58 PM
Ex-Broadband Service Manager
12-12-2012 5:01 PM
12-12-2012 5:05 PM
12-12-2012 8:58 PM
Connected the technicolor back up last night and left on all day. Info now showing is as below. Is this the latest version?
I have carried out a basic test and it's no better at connecting dlna devices. If you can confirm this is the latest version firmware I'll carry out a complete test involving a full power off and restart of every network device, just to be sure. This will take 24 to 72 hours to ensure Ip leasing, sleep, shut down etc all works as it should. I will let you know when this is complete.
Thanks, Chris
System Information
This page summarizes important information on your Technicolor Gateway. You may need this information when you contact your helpdesk.
Product Name: TG582n
Serial Number: <snip>
Software Release: 10.2.2.9
Software Variant: --
Boot Loader Version: 1.0.5
Product Code: 3701603B
Board Name: DANT-T
[Moderator's note by Dick (Strat) Serial number (password) removed from a public forum to a hidden board.
13-12-2012 11:16 AM
Yes, you're on the latest version now. Please try restarting all of the devices but I'd be surprised if this resolved the issues.
We'll have a chat here and work out the next steps and get back to you.
Matt
14-12-2012 10:54 AM
Just to keep you up-to-date. There have been a couple of noticeable changes resulting from the update. The router no longer shows as a media server in its own right. This is great because it was always something that had to be scrolled past as its listing was pointless.
I also note there are some additional management tools available as a result of the firmware update. The MAC scheduler should come in handy after Santa delivers the children's Christmas presents.
The amp picked up the servers last night without any problem - no restarts were necessary, as had been the case previously. I'll give it a more thorough testing over the weekend and report results back next week.
cheers, Chris
16-12-2012 9:46 PM
It transpires that the router will no longer give a working IP address to our Panasonic Blu Ray player (model BDT 210). It keeps giving an unusable address of 169.254.209.4. The player will no longer access the home network drive, DLNA clients or the internet. I've tried resetting the blu ray player and resetting the wireless network it uses from scratch. I did try using a static IP as a test and although I achieved a wireless connection to the wireless network the router prevented wider access. ie the same useless result as auto IP stated above.
The update also seems to on occassion give devices an IP address of 0.0.0.0. The only way to counter this is by deleting the wireless connection through the router's GUI and letting the router give a new address upon the next request.
The router appears to work with all other devices in the house, although I would not call this a full test as I've had to cut it short and switch back to the old Cisco router which works with everything, albeit on wireless g.
Any other ideas. cheers, Chris
19-12-2012 12:23 PM
cheers, Chris
19-12-2012 12:39 PM
Quote from: bigbolam It keeps giving an unusable address of 169.254.209.4.
The router isn't giving this address out, but rather the bluray player is choosing it itself given an unsuccesfull DHCP attempt. As you have found out, an address of this type is useless.
Quote I did try using a static IP as a test and although I achieved a wireless connection to the wireless network the router prevented wider access
Did you set a valid default gateway address on the bluray player?
Quote The update also seems to on occassion give devices an IP address of 0.0.0.0.
Again this isn't the router handing out the address but rather is symptomatic of the device not having a static address set, or having gone through the DHCP process.
Quote The router appears to work with all other devices in the house
I'd be suspecting the bluray player in that case.
Mathew
19-12-2012 12:54 PM
Quote from: MJN Whilst I don't have any answers I thought it might be helpful to correct your interpretation of the symptoms...
Thanks for the clarification.
Yes and set the static within the router range, but at the upper end.
I disagree. Blu ray player was working fine when connected to the technicolor router prior to the firmware update. It (blu ray player) also now works fine with the old Cisco router.
Mathew
Thanks, Chris
19-12-2012 2:08 PM
What static address and gateway did you assign?
