Slow line speed
- Slow line speed
Slow line speed
23-09-2012 9:04 AM
I need max possible upload speed to qualify for an online tuition job...they require min. 500 kbps(0.5Mbps) but I can manage only half that on a good day sometimes.
My stats (thomson speedtouch router)...
Link Information
Uptime: 5 days, 21:32:05
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,200
Data Transferred (Sent/Received) [MB/MB]: 741.60 / 548.70
Output Power (Up/Down) [dBm]: 12.0 / 18.0
Line Attenuation (Up/Down) [dB]: 27.5 / 50.0
SN Margin (Up/Down) [dB]: 19.0 / 9.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 6,080 / 0
FEC Errors (Up/Down): 0 / 198,747,296
CRC Errors (Up/Down): 0 / 448,132
HEC Errors (Up/Down):
btspeedtester shows 0.26 (tested from master socket)(image attached)
all help appreciated, thanks in advance
Re: Slow line speed
23-09-2012 9:42 AM
If you run the diagnostic BT speed test does it do an upstream speed test - if it does then you are on 21CN ADSL1 and you can ask for the upstream to be uncapped.
If 21CN isn't available on your exchange then you would need to ask to go onto Max Premium http://www.plus.net/support/broadband/products/max_premium.shtml
Alternatively - and this is heresy - have a look here and see if there are any LLU suppliers on your exchange as they should give you a higher upload speed http://www.samknows.com/broadband/exchange_search
Obviously the best result is that your exchange is 21CN enabled and then you could ask to be transferred to ADSL2 on it with an uncapped upstream
Re: Slow line speed
23-09-2012 9:52 AM
Re: Slow line speed
23-09-2012 10:35 AM
Re: Slow line speed
24-09-2012 3:56 PM
Re: Slow line speed
25-09-2012 7:30 PM
adie:quote
Re: Slow line speed
29-11-2012 9:19 PM
Reason: No longer required for my work
thanks in advance
Re: Slow line speed
29-11-2012 9:26 PM
As described here http://community.plus.net/forum/index.php/topic,109593.0.html you may want to ask how he did it
Re: Slow line speed
29-11-2012 11:15 PM
Re: Slow line speed
30-11-2012 11:30 AM
I've removed max premium from your account, you will no longer be charged for this service although it will take several days for the max premium to be removed from your line, so you'll still receive the higher upload speeds for a short while.
