Unable to access most web sites with new Linksys E4200 Router
leahk
I've been on FTTC since March and had no problems with the service.  My router,  however, an Apple Time Capsule, was not so reliable and needed a reboot every few days,
So after reading various reviews, I chose the Cisco Linksys E4200 V2 - a top of the range router with lots of useful functions.
The Setup completes OK and PPPoE logs into Plusnet fine.  But then I hit the problem.
Most of the websites I use simply won't load .
In Safari on my OS X Lion, Macbook, I get an error like this "Request Timeout. The server timed out while waiting for the browser's request. Reference #2.525fdd58.1336048435.0"
In IE on my Windows XP laptop, the error is "Internet Explorer cannot display the webpage"
But some websites still load fine.  So bbc.co.uk, loads instantly.
Most other sites I try, including www.plus.net and www.apple.com - won't load at all.
If I connect to my work VPN, I can browse as normal.
I have both wired and wireless computers, it makes no difference to the problem.
I did some searches on the internet for help, and the only suggestion was the MTU settings so I tried those suggestions, but still no joy.
I even suspected a faulty router so sent it back and got a replacement,
I am pulling by hair out on this one, so any help would be greatly appreciated.
33 REPLIES 33
jojopillo
Re: Unable to access most web sites with new Netgear E4200 Router
Hi leahk,
Can you run traceroutes to those site and see what you get?
Jojo Smiley
Oldjim
Resting Legend
Fixes: 63
Reading some other problems with Netgears with FTTC can you try putting in fixed DNS servers into the router
leahk
Thanks for the reply - trace route output below.
With further testing, there appears to be 4 different symptoms depending on the site.
  • Works Fine
  • Very slow to load but get's there in the end (after about 30 seconds)
  • Very slow and incomplete
  • Doesn't load at all.
here are the results from a few sites:
www.b3ta.com - slow
www.neowin.net - slow and external content missing
www.the register.co.uk - slow
slashdot.org - does not load
www.engadget.com - does not load
www.14u.com - slow
www.gizmodo.co.uk - slow and missing content (like ccs)
www.switched.com - does not load
$ traceroute www.bbc.co.uk
traceroute to www.bbc.net.uk (212.58.246.94), 64 hops max, 52 byte packets
1  potatoe (192.168.1.1)  2.716 ms  0.633 ms  0.591 ms
2  lo0-central7.pcl-ag08.plus.net (195.166.130.125)  11.565 ms  11.175 ms  11.050 ms
3  84.93.251.219 (84.93.251.219)  11.144 ms  10.584 ms  10.793 ms
4  po4.pcl-gw01.plus.net (212.159.1.128)  10.973 ms  11.705 ms  11.066 ms
5  ae3.pcl-cr01.plus.net (195.166.129.40)  10.837 ms  10.707 ms  10.983 ms
6  ae1.ptw-cr01.plus.net (195.166.129.0)  10.722 ms  10.372 ms  10.902 ms
7  kingston-gw.thdo.bbc.co.uk (212.58.239.6)  11.460 ms  10.946 ms  11.073 ms
8  * * *
9  ae0.er01.cwwtf.bbc.co.uk (132.185.254.93)  12.468 ms  12.376 ms  11.912 ms
10  132.185.255.165 (132.185.255.165)  12.612 ms  15.592 ms  12.460 ms
11  bbc-vip015.cwwtf.bbc.co.uk (212.58.246.94)  11.981 ms  12.038 ms  12.275 ms
$ traceroute www.apple.com
traceroute to e3191.c.akamaiedge.net (2.19.237.15), 64 hops max, 52 byte packets
1  potatoe (192.168.1.1)  3.582 ms  0.618 ms  0.572 ms
2  lo0-central7.pcl-ag08.plus.net (195.166.130.125)  11.162 ms  11.544 ms  11.260 ms
3  84.93.251.219 (84.93.251.219)  11.786 ms  10.734 ms  10.704 ms
4  po4.pcl-gw01.plus.net (212.159.1.128)  11.335 ms  11.551 ms  11.052 ms
5  ae3.pcl-cr01.plus.net (195.166.129.40)  10.789 ms  10.717 ms  10.782 ms
6  ae1.ptw-cr01.plus.net (195.166.129.0)  11.243 ms  11.117 ms  11.234 ms
7  te9-4.ptn-gw01.plus.net (195.166.129.33)  11.648 ms  11.041 ms  11.145 ms
8  195.99.126.144 (195.99.126.144)  10.782 ms  11.112 ms  11.017 ms
9  core2-te0-0-0-10.ealing.ukcore.bt.net (109.159.254.109)  15.251 ms  23.462 ms  25.946 ms
10  peer3-te0-2-1-0.telehouse.ukcore.bt.net (109.159.254.144)  15.033 ms  18.428 ms  15.480 ms
11  195.99.126.78 (195.99.126.78)  14.217 ms  13.857 ms  14.446 ms
12  * * *
13  * * *
14  * * *
15  * * *
16  *^C
$ traceroute www.plus.net
traceroute: Warning: www.plus.net has multiple addresses; using 212.159.8.2
traceroute to portal.plus.net (212.159.8.2), 64 hops max, 52 byte packets
1  potatoe (192.168.1.1)  2.761 ms  0.623 ms  0.610 ms
2  lo0-central7.pcl-ag08.plus.net (195.166.130.125)  11.293 ms  13.781 ms  12.215 ms
3  84.93.251.219 (84.93.251.219)  11.556 ms  11.096 ms  10.638 ms
4  po4.pcl-gw01.plus.net (212.159.1.128)  22.544 ms  22.503 ms  23.381 ms
5  ae3.pcl-cr01.plus.net (195.166.129.40)  10.810 ms  10.708 ms  10.733 ms
6  ae1.ptw-cr01.plus.net (195.166.129.0)  11.060 ms  11.141 ms  10.943 ms
7  te9-4.ptn-gw01.plus.net (195.166.129.33)  22.548 ms  22.456 ms  22.952 ms
8  gi3-0.pih-cr1.plus.net (212.159.1.177)  22.237 ms  22.435 ms  22.106 ms
9  if25.pih-lb04.plus.net (212.159.0.18)  22.260 ms  21.917 ms  22.324 ms
10  if25.pih-lb04.plus.net (212.159.0.18)  22.386 ms  22.422 ms  22.557 ms
$ traceroute www.engadget.com
traceroute: Warning: www.engadget.com has multiple addresses; using 149.174.97.30
traceroute to win.blogsmith.aol.com.aol.akadns.net (149.174.97.30), 64 hops max, 52 byte packets
1  potatoe (192.168.1.1)  1.170 ms  0.722 ms  0.667 ms
2  lo0-central7.pcl-ag08.plus.net (195.166.130.125)  12.314 ms  17.393 ms  16.941 ms
3  84.93.251.219 (84.93.251.219)  141.043 ms  102.089 ms  98.979 ms
4  po4.pcl-gw01.plus.net (212.159.1.128)  11.015 ms  11.043 ms  10.669 ms
5  ae3.pcl-cr01.plus.net (195.166.129.40)  14.863 ms  11.015 ms  10.576 ms
6  xe-11-2-0.edge3.london2.level3.net (212.187.201.213)  10.989 ms  10.983 ms  10.841 ms
7  ae-0-11.edge4.london2.level3.net (4.69.200.126)  15.035 ms  11.675 ms  10.580 ms
8  ae-3-3.ebr1.london1.level3.net (4.69.141.189)  10.956 ms  11.285 ms  10.915 ms
9  ae-58-113.csw1.london1.level3.net (4.69.153.122)  10.937 ms
    ae-56-111.csw1.london1.level3.net (4.69.153.114)  11.137 ms  13.827 ms
10  ae-1-51.edge3.london1.level3.net (4.69.139.73)  10.975 ms  11.298 ms  11.067 ms
11  bb2-loh-xe-0-1-0.atdn.net (66.185.145.201)  11.494 ms  11.368 ms  11.193 ms
12  bb2-vie-s7-1-0.atdn.net (66.185.152.96)  99.500 ms  115.809 ms  99.163 ms
13  dar2-mtc-xe-2-1-0.atdn.net (66.185.152.109)  98.582 ms  98.249 ms  164.641 ms
14  edge2-atc-ae1.net.aol.com (66.185.143.6)  101.470 ms  105.513 ms  101.423 ms
15  * * *
16  * * *
17  * * *
18  * * *
jojopillo
Hi leahk,
Thanks for that. Those sites work fine for me and some of them are very popular so I'd expect lots of complaints if it was a routing issue. Have you a different brand of router you can try? Are any other forum members looking at this thread having any trouble with these sites?
Jojo Smiley
GrahamC
Everything OK here, the listed sites loading fast... Smiley
On ptn-ag03
cheers
Graham
leahk
I know the cause is the router - if I swap my old one back it works fine. - This appears to be a problem that affects this model of router (as this is the  second one I have tried).  But I have read reviews from other who are using it with FTTC with no problem so it appears to down to something in my connection that don't like the router.
mattturner
Hi LeahK
If you get us a Wireshark capture while these requests are failing, we might be able to work out what's going wrong.
Matt
frank39
I think there may be an error in the title of this thread.  The E4200 is not a netgear router, I think it is Linksys
leahk
:-[Good point  - I meant to say the Cisco Linksys E4200 V2
dick:quote
leahk
Quote from: Matt
Hi LeahK
Matt
Thanks - I've got a capture from Wireshark - where do I upload it to? (It's not one of the permitted attachments in the forum)
jojopillo
Re: Unable to access most web sites with new Linksys E4200 Router
Hi leahk,
You'll need to zip it up and attach it to a ticket. It can't be more than 4MB in size though. Let me know when you've done it and I'll get it looked at.
Jojo Smiley
leahk
Thanks again Jojo.
I've raised ticket 55117615 and uploaded the Wireshark capture to it.
Kevin Leah
leahk
Aspiring Hero
Fixes: 73
This is an odd issue, it could be down to do with DNS being confused, from your trace route it show 192.168.1.1 being the DNS host for your device. Have you tried using a another DNS IP address rather than relying on your router? What I mean by this is to set DNS IP in the NIC properties
Try using 212.159.13.49 and 212.159.13.50
Just noticed oldjim has already suggested a DNS issue, did you try what he suggested?
Dan.
mattturner
Hi Kevin,
I'm not 100% sure what is going on here. I can see TCP sessions being set up correctly, but data within these sessions isn't being received by the remote host and your computer is repeatedly trying to resend it.
Could you please try configuring your routers firewall state to disabled (only temporarily) to see if this fixes it?
If this doesn't work, then please could you try to capture a longer file? We can only see one complete TCP session in you capture, a few other would be good, some that work and some that don't within the same file would be useful.
Thanks,
Matt
