Technicolor TG582n Configuration - Static IP
- Technicolor TG582n Configuration - Static IP
29-04-2012 11:21 AM
I am just looking to set up my router as I haven't had chance since I got the broadband installed. I am a bit lost when it comes to setting up some of the options though as the user interface is a little basic in places.
First off I want to be able to change the DHCP so that is assigns addresses in the 192.168.0.* range then I want to assign specific IP addresses to devices but I cannot find anywhere in the settings to do this. When I look at the devices I can see the IP they are assigned but not change them. where is this option?
Any help appreciated!
Re: Technicolor TG582n Configuration - Static IP
29-04-2012 2:24 PM
If you change anything don't forget to click the Apply button.
29-04-2012 3:00 PM
There is an option to always use the same IP address which I guess is creating a static IP but that would be only half of what I want really.
29-04-2012 7:07 PM
29-04-2012 11:36 PM
05-08-2012 6:05 PM
Telnet into the router (same name and password as the web interface) and then do the following:
dhcp server lease list (lists the current DHCP clients)
dhcp server lease delete clientid=xx:xx:xx:xx:xx:xx ( xx etc. is the MAC address of appropriate client from above list - deletes the current lease)
dhcp server lease add clientid=xx:xx:xx:xx:xx:xx pool=LAN_private addr=192.168.1.x leasetime=0 (adds required IP for appropriate client with infinite lease time)
saveall
Then reboot PC or whatever to get the new lease.
05-08-2012 6:12 PM
04-02-2014 1:00 PM
Came across this thread whilst searching how to set up static IPs and DHCP on a TG582n, and found the attached document that others will find useful.
I've got to say that the TG582n is probably the worst, most user unfriendly router I've had the misfortune to use, I'm just glad I don't need to delve into it to alter things very often.
04-02-2014 1:15 PM
For the bulk of non-technical users, it plugs in and it works with MINIMAL setting up. If such users do go into the web interface there is little that they can totally screw-up by accident.
However for the technically more savvy / demanding of us, the user interface restrictions is indeed a right pain in the rear end. That said, the telnet interface (which tech savvy users should be able to work with) does give access to tweaking nearly anything you care to fiddle with. That includes inhibiting the factory reset capability!!!
From experience, I think that many of the 'more flexible' devices present a far too complex UI for the majority of users.
Cheers,
Kevin
04-02-2014 2:04 PM
Can you post a link to the Telnet information.
04-02-2014 2:33 PM
Try this for starters - http://npr.me.uk/ - provided by 'npr' one of the regular PN customers posting on here. There is a LOT of detailed and useful information here. Please use with care though!
Kevin
09-02-2014 11:12 PM
The big pity is that Plusnet's support staff don't know how to do this on their own router. They referred me to get support from Techicolor, which would be OK if it wasn't for the fact that when you log on to the router it has a Plusnet logo on it, indicating that Plusnet at least has some 'ownership' of the router.
12-02-2014 5:34 PM
Quote from: batchelorboy Having looked at Telnet and other solutions, I have finally found how to get fixed IP addresses within the TG582n's own GUI.
OK, the downside is that you don't get to pick the IP address - you have to use the one that DHCP gives you. Also, you will have a problem if your device cannot use DHCP to get an IP address.
Hello, I am trying to see if I can get around a problem like this.
I am using a Plusnet technicolor Tg582n router. I have an elderly HP LaserJet 5m printer with an HP JetDirect card, which I prefer to connect to the router via ethernet. Trouble is, the firmware in the JetDirect card is so old it doesn't know about DHCP (just RARP or BOOTP). With a previous D-Link DSL 2680 router, using the internal router support web pages, I was able to restrict the router assigned DHCP address range and enter a static IP and ethernet address for the printer. This worked fine.
Does anyone have any idea if the Tg582n can be induced to support BOOTP, for backward compatibility with static device addresses outside the DHCP range, as my old D-Link router can?
Thanks in advance.
12-02-2014 9:09 PM
Thanks to quelquod.
Though I did this by placing the LaserJet IP address inside the DHCP range, rather than outside, as I expected.
Looks as if it just needs a bit of tidying up as I get the "Unknown-<MAC address>" title in the Technicolor Admin pages. Would be nice to see "LaserJet 5m"! Could it be that clientid should be a name string rather than a MAC address? Because I also entered the MAC address later in the command, when requested.
17-04-2014 10:29 AM
Quote from: quelquod The TG582n web interface is pretty restricted - you can't set up static DHCPs from it - you need to use the command line.
saveall
Thanks for this quelquod, works for me
