Really Bad Tonight
- Really Bad Tonight
Really Bad Tonight
31-01-2012 9:04 PM
nowt on exchange checker, bt speedtest shows a 50% drop in speed
exchange is undercliffe normally get 14 - 16 down
jim:green After numerous requests - see the latest posts - and the fact that is was getting on my nerves - I have changed the spelling in the title mod:end
Re: realy bad tonite
31-01-2012 9:23 PM
31-01-2012 9:43 PM
PS YES am in test socket , not wifi , only 1 pc and 1 phone
lol just checked i am slower than 96% of the uk
01-02-2012 6:49 AM
01-02-2012 9:00 AM
N.B. Your issues may not have had anything to do with your gateway and power cycling your router will clear myriad things which could be causing problems!
01-02-2012 9:10 AM
I didn't change gateways & it was back to normal by 11:30 p.m. (Gateway ptn-ag01)
01-02-2012 9:20 AM
i regulary have to restart my router to clear thousands of errors which as you say helps for a while , also have done hard reset of router & reset to defaults but the evening connection problems always returns , have swapped the router several times .
its not my PC i did a full reinstall a few weeks back , i run Hijack this regular , malwarebytes & C cleaner , i use windows firwall and security essentials .
and dont have extra autoruns and background progs running , i check with MSCONFIG and widows services what i have running and dissable what i dont need.
have asked several times & had my line checked by PN but nowt was found all ok , but obviously there must be a problem somwhere , i do realize intermittant problems are the worst to find , if i run wireshark its ok but if its not running ya can be sure i will have problems.
and also its hard to upload a Pcap file , which is large coz i had it running several hours .
PS i must have nocturnal Gremlins
01-02-2012 9:33 AM
Ex-Broadband Service Manager
01-02-2012 12:20 PM
01-02-2012 1:38 PM
01-02-2012 1:42 PM
01-02-2012 2:00 PM
01-02-2012 2:17 PM
connectivity to Gateway (195.166.130.91)
and as i have said last night was worst ! BUT i get it most nights !!!
01-02-2012 5:27 PM
Current list of busier gateways on WBC (21CN):
pcl-ag03
pcl-ag01
pcl-ag04 *
pcl-ag05
pcl-ag08
ptn-ag2
ptn-ag03 *
ptn-ag04 *
* The asterisk'd gateways actually have two different end points, only one of each has higher-than-average users. I don't think you'll be able to tell which one you're on so don't panic if you find yourself connected, test your connection and leave it if it's OK.
N.B. This list is correct as of now and will change so please don't pay any attention to it tomorrow
N.B.2. We have over 30 end points so this still only represents a small part of our network that is out of balance
N.B.3. Don't keep power cycling your router unless you want DLM to kick in. Once or twice is fine but any more than that and you really want to drop the PPP connection from the router interface and re-start it so you don't re-sync.
01-02-2012 5:46 PM
aparently i am now on pcl-ag02. which looks good
